D3 with XM radio will not keep the presets.
By dwhitley0381 · Feb 24, 2008in Problems/Troubleshooting💬 6 posts👁️ 718 views
Posted Feb 24, 2008 · 00:42 UTC#1
Every time I turn off the radio the presets go back to 0 and lose the programing. Any ideas? Thanks for the help
Posted Feb 24, 2008 · 00:51 UTC#2
When you turn off the radio or when you turn off the car? Sounds like the 12v power supply might not be connected correctly.
Posted Feb 24, 2008 · 01:22 UTC#3
Yea its dark now I will take a look in the morning.. I may have a lose wire or something it was working when I set everything up but when I disconted the wires to the XM unit so that I could mount it in the dash and then got it all put away that is when it stopped working holding the presets.
Posted Feb 24, 2008 · 02:44 UTC#4
you have the yellow wire from the xm connected to an accessory instead of a constant
Posted Feb 24, 2008 · 03:07 UTC#5
See thats strange cause I cut the wires to the Sirius and put the new end on that gives the XM its power. The Sirius never lost its presets.. I will test to make sure that its has contant power... I am sure it was holding the channels until I disconnected and stuck everything in the dash and reconnected that is when it started losing. I have read that I may have to do a reset. If anyone else has had this happen let me know.. but thanks for all the info so far...
Posted Feb 25, 2008 · 03:36 UTC#6
Ok well I did not have the constant power to the xm box so now its working. holding the presets... thanks for the help....
