No ring tone or voice from bluetooth
By T100 · Feb 25, 2008in Problems/Troubleshooting💬 10 posts👁️ 1,446 views
Posted Feb 25, 2008 · 15:59 UTC#1
I have a nokia and have used this phone for some time an now it has developed a symptom of win bluetooth is off on my phone my screen say connected . I connect from phone menu and try to make a call and and it calls according to phone off hook symbol and have no ring tone ,also the phone is answered and i cant hear no one on the other side. I have done a level 3 reset with no success.
Posted Feb 25, 2008 · 16:21 UTC#2
Did you also delete the Z2 from your phone after the level reset, before re-pairing?
Posted Feb 25, 2008 · 16:28 UTC#3
Yes i did and reapplied it afterwards
Posted Feb 25, 2008 · 17:15 UTC#4
when you're on a call, and it's happening, Look on your phone for an Options menu or something like that, and see if you can find something like "send audio to headset"
Posted Feb 25, 2008 · 23:01 UTC#5
This phone has just started this its a nokia 6305 and has been working perfect and all the sudden started this. I just performed a level 4 reset with no success. I guess i will try to unplug the bluetooth from the z2 and replug it and go from there, also I have notice no xm status in menu I know this has been talked about in other posts but have never resolved it. I'm pretty informed in the setup of the unit, I teach nav and bluetooth and how to use your car for lexus custmers at our dealership. So it must be a interface condion. Thanks for your help.
Posted Feb 25, 2008 · 23:06 UTC#6
Your problem with the xm status is a common one. It depends on which tuner you have.
GEX-XM10T - will say that if the data cable is bad or not connected.
GEX-P910XM - Will always say that since it lacks the data cable required to send the information to the avic
TERK XMD1000 & XMDPIO110 combo - Again will always say that since it lacks the data cable to send the infor to the avic.
Posted Feb 26, 2008 · 00:30 UTC#7
I disconnected and reconnected my bluetooth port with no success. Also called my cell from home and could not hear anything until I put cell into loudspeaker mode, and phone went cell mode.
Posted Feb 26, 2008 · 00:43 UTC#8
Time to try a different phone to rule out if it's the Head unit or the phone. Got a friend willing to pair to your Z?
Posted Feb 18, 2010 · 22:59 UTC#9
Was a solution ever found for this problem? I am having the same problem now.
Posted Jul 31, 2010 · 22:49 UTC#10
Having the same problem bluetooth was working but now when a place a call or someone calls me i here a little pop and get no voice or dail tone.
