HELP with D3 BLUETOOTH in 05 G35 Coupe!!!
By g35x · Feb 25, 2008in General💬 9 posts👁️ 1,325 views
Posted Feb 25, 2008 · 22:37 UTC#1
Hey all i got a problem with my D3... Got the D3 along with the bluetooth and ipod interface. Installed everything correctly (i hope) and bypassed worked as well. Now i cnt figure out why my bluetooth wont sound through the speakers. Any suggestion or answers as to why? It CAN connect as i used two different BT phones as well. I dial but i hear. I did a test to see if the other person on the opposite side of the line can hear my voice and they can. But the only thing is I cant hear them through my car speakers as it should. I hope this information could help someone help me identify the problem to this. If u need further details do ask. Thanks in advances Avic D'ers! =D
Posted Feb 25, 2008 · 22:55 UTC#2
put the ipbus cable in the other port of the btb200. That give you sound?
Posted Feb 25, 2008 · 22:59 UTC#3
Shouldn't it go in the center one?
Posted Feb 25, 2008 · 23:01 UTC#4
it should go into the one marked ipbus output.
Posted Feb 26, 2008 · 07:01 UTC#5
yep did that still dint work...
Posted Feb 26, 2008 · 17:32 UTC#6
You have the power & gnd correctly connected?
Posted Mar 03, 2008 · 16:50 UTC#7
yepp
Posted Mar 03, 2008 · 18:03 UTC#8
OK, so everything is fully functional, but you can't hear the other person. You see all of the BT options on the screen? You can place calls using the BT interface on the D3?
Only thing I can think of is a bad BT module...
Posted Mar 03, 2008 · 18:34 UTC#9
Could be an incompatible phone, too. Try it with a friend's BT compatible phone.
