Avic N1 In Maxima
By Nflplaya882 · Feb 26, 2008in Problems/Troubleshooting💬 4 posts👁️ 938 views
Posted Feb 26, 2008 · 02:11 UTC#1
I currently have a 98 camry and the avic n1 fits perfectly. Pretty soon I am going to upgrade to a 03 Maxima. Is it possible for the avic n1 fit in the maxima fine? Will I need a dash kit? What kind of harness will I need? I also know that the maxima has a bose system. Please let me know what I am going to need and where I can find it to make this happen.
Posted Feb 26, 2008 · 02:19 UTC#2
dash kit 99-7416
harness 70-7551
Antenna adapter 40-ni10
Speed Sense pink/blue instrument cluster, 20 pin brn plug
DO NOT start the car with the instrument cluster unplugged. Can also find the wire at the ECM located in the front of the center console on the transmission hump.
Reverse Light green/white + driver kick, harness to rear
Posted Feb 27, 2008 · 00:48 UTC#3
dash kit 99-7416
harness 70-7551
Thank You
Posted Mar 06, 2008 · 03:43 UTC#4
Ok so I decided to buy the 2004 Maxima. There Is one problem tho. Do you think its worth putting in the avic n1 because the dash is so complex. If so what will I need.
Also Is it possible to just use nissan's stock radio to hook up subwoofers?
I have the factory bose system in the car now. If this will work please let me know how I can make this happen. Pics will be greatly appreciated.
Thank You
