Maybe this helps you guys understand my problem a bit... I don't have the brown wire which is supposed to be connected to the mute wire connected as well as the
1. Connect the yellow wire to the radio’s 12V battery or memory wire.
Yes, did that
2. Connect the red wire to the radio’s ignition or accessory wire.
Yes, did that
3. Connect the black wire to the radio’s ground wire.
Yes, did that
4. Connect the orange wire to the radio’s illumination wire. If the wire is not present, tape up wire.
Connected the orange wire to the Orange/White wire from the D3 harness which is labelled "ILL"
5. Connect the orange/white wire to the radio’s dimmer wire. If the wire is not present, tape up wire
Didn't connect this to anything, don't see a dimmer wire to connect it to
1. Connect the blue/white wire to the radio’s AMP turn-on wire.
Connected to the blue/white wire from the D3 harness which is labelled "power amp"
2. Connect the red wire to the radio’s Igniton or accessory wire.
Connected to red wire on D3 harness which is labelled "electric terminal controlled by ignition switch (12 V DC)
3. Connect the RCA cables to the radio’s RCA outputs. If no RCA outputs are
available, use the Metra line output converter part #ALO-648 (SOLD SEPARATELY).
4. The white RCA goes to the left front RCA output of the radio.
5. The gray RCA goes to the front right RCA output of the radio.
6. The green RCA goes to the left rear RCA output of the radio.
7. The purple RCA goes to the right rear RCA output of the radio
Done
The following wires on the 14 pin harness are for the aftermarket radios that have navigation
built in:
1. Connect the Brown wire to the mute wire of the aftermarket radio.
Not hooked up to anything. I don't have it hooked up to anything because I did the video bypass so I was under the impression just to tape it up
2. Connect the Green wire to the parking brake wire of the aftermarket radio. (Unless you did the AVIC bypass)
I did the bypass
3. Connect the Blue/Pink wire to the VSS or speed sense wire of the aftermarket radio.
Not connected
4. Connect the Green/Purple wire to the reverse wire of the aftermarket radio.
Not connected
Also, I do not have the "auto-antenna relay control terminal" connected to anything. Should it be? Also should the brown wire be tapped into the mute wire?
If anyone can help me out I'd appreciate it...
