Phone P1-6 Numbers?
By dgilling0714 · Feb 27, 2008in General💬 15 posts👁️ 2,435 views
Posted Feb 27, 2008 · 23:54 UTC#1
Is there any way to set the programmed numbers to display the name and not the number on the first BTB screen. the Preset numbers...
I know there is only a few but i would rather look at a name.
Posted Feb 28, 2008 · 02:53 UTC#2
sure is.
right on that screen there is button that reads "Name/Number".
toggling through that button will switch your presets from name to number display
Posted Feb 29, 2008 · 13:44 UTC#3
sure is.
I've figured out how to switch back and forth between name and number but the name is always "no name". How do I rename this?
Posted Feb 29, 2008 · 16:34 UTC#4
you cant rename it.
in order for you preset to show a name, that number must be saved in the btb internal phonebook which you should have uploaded from your phone.
if you dont it wont ever show a name because that name and number is not saved in your phonebook.
Posted Feb 29, 2008 · 21:40 UTC#5
Which is exactly the case with the iPhone.
You can save a phone # on the D3 directly based on your call log but you cannot change the display name since the iPhone doesn't transfer it's address book to the D3.
Posted Mar 20, 2008 · 12:25 UTC#6
you cant rename it.
So, does this mean if I can't transfer my cell address book into the D3, I can't name my presets?
My current phone, Motorola V557, doesn't transfer my address book to the D3 (or at least I haven't found a way). I added a number to the preset through the dialed call log. I can't name it?
Also, is there another way to add to the presets besides going through the log?
Posted Mar 20, 2008 · 18:12 UTC#7
I have three motorolas that all send contacts fine. If for whatever reason you can't send them over, you will not be able to name them on the D3
Posted Mar 20, 2008 · 18:43 UTC#8
Any hints on sending them. I have a Motorola V557. When I go to copy the contacts the only options I get are Phone Memory and SIM. Is there another way to do this?
Posted Mar 20, 2008 · 19:11 UTC#9
Don't use copy, all that does is select whether you have your phone numbers stored on the sim card or the phone.
Try selecting each contact, hit options, and you should have an option that says something like send contact, or share address book entry, or send v-card. Its different for each carrier so you may have to read the manual of your phone to check
Posted Mar 20, 2008 · 19:20 UTC#10
theres is another way...
from the direct dial screen, dial the number you wanna save
then press add/store/save, or something to that affect,...
then it will sned you back to the p1-p6 screen.
on the top strip of the screen should be the number you just input.
just touch and keep you finger on the preset you want and it will save it.
you cant rename it.
Posted Mar 20, 2008 · 20:10 UTC#11
Found it. Thanks Whtcrxghst. I missed it, it's at the bottom of the page (I didn't scroll enough, Doh), Share Phonebook entry. Sorry, I look harder next time. The phone's manual doesn't say crap about any of this, believe me, I looked.
Mrgoodbar67, thanks also. I didn't know that method. I'm usually pretty good at figuring things out. But, not this time.
I'm happy.
Posted Mar 20, 2008 · 20:59 UTC#12
:wink:
Posted Mar 20, 2008 · 21:05 UTC#13
NO PROB BRO
Posted Mar 22, 2008 · 05:30 UTC#14
GOD!!!! when is apple gunna fix this bluetooth problem???
Posted Mar 22, 2008 · 10:05 UTC#15
When they find a way to make people pay for it :x
