When turning on car, it says " improper break lead&quot
By supernet · Feb 29, 2008in Problems/Troubleshooting💬 6 posts👁️ 822 views
Posted Feb 29, 2008 · 21:49 UTC#1
When turning on car, it says " improper break lead"
is that because of my by pass?
Posted Feb 29, 2008 · 23:29 UTC#2
i had that same issue, until i did the the bypass the correct way.
Posted Feb 29, 2008 · 23:45 UTC#3
What was wrong with urs???
Posted Mar 01, 2008 · 00:17 UTC#4
Check your work!
Posted Mar 03, 2008 · 16:14 UTC#5
I've only seen this one time. AND IT WAS YESTERDAY on an N2! When we bench tested it before installing, it came up with that alert. No biggie I think. (Obviously because the wire isn't connected to anything) But then the alert continued after installation. I'm positive I hooked up the parking brake wire to the correct wire on the parking brake. Video even displays fine with parking brake engaged...... so I'm stumped.
PS. I'm not attempting any type of bypass. My job is more important than some random shmuck's "wants".
PPS. And $100 cash doesn't even come close to changing my mind.....lol
Posted Mar 03, 2008 · 16:22 UTC#6
Maybe the pin where the parking brake wire goes into the D3's harness came loose? I can't find anything about that error message in the manual... But maybe I just didn't read carefully enough.
