Traffic Button not highlighted in menu, this normal?
By supernet · Mar 01, 2008in General💬 16 posts👁️ 2,343 views
Posted Mar 01, 2008 · 17:32 UTC#1
I signed for XM traffic
Posted Mar 01, 2008 · 19:05 UTC#2
Do you have the GEXP10XMT and the data cable connected? Do you have your deck bypassed, Or the parking brake on? Do you have traffic coverage in your area? If you answered yes to ALL of those, then XM didn't activate your traffic service properly
Posted Mar 02, 2008 · 00:56 UTC#3
I have XM and Nav traffic box? I had an installer do all this!
I can get Nav traffic updates, so hrmm what could be wrong?
If i HIT the traffic xm thing
Posted Mar 02, 2008 · 01:39 UTC#4
Ok I called XM and they said I for sure have Nav traffic!!
And i just did a refresh and still nothing!
Do you think the installer screwed up!
Posted Mar 02, 2008 · 02:16 UTC#5
Mine does the same thing. I think the button only activates if you have a route selected. (Cause that is normally how it works from the map screen,otherwise it just shows you traffic incidents in the area).
Posted Mar 02, 2008 · 02:20 UTC#6
Well even when I have a route in there it dosn't show up
I am willing to PAY someone if they can help me with this thing!
Posted Mar 02, 2008 · 02:46 UTC#7
That button works even when you don't have a route plotted.
I will ask you again...Did you have the deck bypassed? If not, have you tried putting the parking brake on and pressing it?
Posted Mar 02, 2008 · 03:22 UTC#8
The bypass is working PERFECT!!!
Posted Mar 02, 2008 · 03:29 UTC#9
I also would like to know how to make it "auto" tell me if there is something wrong in my route!
Posted Mar 02, 2008 · 06:53 UTC#10
make sure the installer ran the data cable if using the 2 piece system
Posted Mar 02, 2008 · 10:43 UTC#11
On your map screen, is the traffic button highlighted?
Posted Mar 02, 2008 · 15:53 UTC#12
Yes, but when ever i press it .. it says " there is no information for this route"
Posted Mar 02, 2008 · 15:58 UTC#13
If you mean this, then yes!
Posted Mar 03, 2008 · 04:34 UTC#14
bump, anyone know?
Posted Mar 03, 2008 · 21:35 UTC#15
So should that button be high lighted ?
Posted Mar 04, 2008 · 02:18 UTC#16
Mine is. Did you check if the data cable is plugged in on both ends?
