can someone tell me where to find it? thanks
where's the vss wire in a 99 eb expedition?
isnt this like the 10th time you've posted this?
i made my own post asking where it's at under the Vehicle Specific Wiring section. i figured i'd try here to find out so that i could finish the hook up.
Speed Sense gray/black cruise control module
The cruise control module is on the driver side fender. Also found in the radio harness on some models.
Speed Sense gray/black cruise control moduleThe cruise control module is on the driver side fender. Also found in the radio harness on some models.
ok, where at on radio harness on which set of wires, the one for the disc changer or one of the other 2? mine has 3 sets that go to the back of stock radio. thanks
there is 2 or 3 plugs behind the radio, one 16 pin plug is the main harness, one 20 pin plug, in the 20 pin plug pin 9 is the grey and black wire, that is the speed signsl wire, if you looked behind the radio it will be the only grey/black wire behind the radio in all of the plugs.
thank you. i'll look tomorrow
