PROBLEM D3 US/EUROPE PLEASE HELP !!!
By cindy947 · Mar 02, 2008in Problems/Troubleshooting💬 13 posts👁️ 1,565 views
Posted Mar 02, 2008 · 15:13 UTC#1
HELLO TO ALL
I COME TO BUY A PIONEER AVIC D3 TO USA
AFTER INSTALLATION SCREEN REQUEST FOR ME INSERER DISC APPROPRIATE ...
I GIVE HIM DVD NAVIGATION EUROPE: DISC REPLACEMENT NAVIGATION APPLICATION DISC.
IDEM FOR NAVIGATION US DVD
AWARE THAT THIS POST IS PROVIDED QU'AVEC THE NAVIGATION DVD ....
SOMEONE HAD THIS PROBLEM AND HELP ME?
Posted Mar 02, 2008 · 16:43 UTC#2
European nav disks do not work in American D3's, and American nav disks do not work in European D3's.
If that is what you're asking... ?
Posted Mar 02, 2008 · 17:55 UTC#3
The same cd us not working he said inserted the disc d d application
Posted Mar 04, 2008 · 19:14 UTC#4
Does that mean that the D3 you are using is the USA version?
Is that the European D3 update disk? Because there are no US upgrade disks and European disks do not work in the US units.
Posted Mar 04, 2008 · 22:21 UTC#5
I am in Europe
I bought a D3 in the USA supplied with the DVD USA 2
I do not need the GPS function
I know that the nagivation EU does not fit on the USA D3
I just want to be able to walk to the radio and read videos.
Posted Mar 04, 2008 · 22:31 UTC#6
Well I'm not sure why it wouldn't let you use the disk it came with... Unless it locks you out if you are trying to use a disk that covers an area other than where the GPS signal tells you it is? Try unhooking the navigation antenna, do a system reset (with the power on, push the little pinhole button for a few seconds on the top right of the face), and start over without the nav antenna plugged in so the unit doesn't know where it is. It might not be the problem, but it's fairly easy worth a shot.
Posted Mar 05, 2008 · 17:00 UTC#7
At the start of your post that you had already done it?
Posted Mar 05, 2008 · 17:03 UTC#8
Posted Mar 06, 2008 · 20:17 UTC#9
HI, did u finally find any EU maps for ur pioneer system
Posted Mar 06, 2008 · 23:13 UTC#10
Is it possible that the dvd region code is wrong? If your trying to watch european DVD's on an american dvd player it's not going to work. US is region 1 and majority of Europe is region 2.
Posted Mar 08, 2008 · 19:23 UTC#11
Posted Mar 09, 2008 · 11:45 UTC#12
I use the DVD navigation and us and I always put the same message ... I can not use my d3 that blocks because of that, I burned the DVD and it is always the same message I do not know what to do ...
Help
Posted Mar 10, 2008 · 03:00 UTC#13
You say you burned the DVD... It's not an original copy of the disk? If it's something you downloaded and burned to a disk, how can you be certain it's the correct disk? If it's a copy of the disk you got with the D3, it could just be a bad burn, try burning another copy and see if the same thing happens, or use the original disk.
