Teh New Steering wheel. I Have an 08 Lt1, and would like the steering wheel controls as well. I have ordered the SR-1 to mount onthe wheel itself, but the new wheel would be better.
Do you have the part number and cost? as far as replcing it, did you have to pull the airbag? I work as a custom audio installer so Im sure i can handle it just want to know whats involved.
As far as installing, yours looks nice, however for others there is an easier way. I see he used a chime module to retain door chime, and then a Pac Audio adaptor.
Metra Electronics makes and Adaptor that will do everything for you.
check metraonline.com for exact part number. This adaptor will give you the following.
VSS (speed sense) output
Reverse Output
Door chime is built into the module
Retains Onstar (Onstar works 100%)
Has speaker in and out for your new radio
Parking Brake output
Turn signal output.
The custom shop I work at doesnt carry the Pac-Audio parts, so im not sure exactly what the part pictured will or wont do, but I see that it doesnt do Reverse or VSS, Also the Metra part has the door chime adaptor built into it where the chime still comes out your door speaker.
Its 1 module that picks up all the info from the truck Via Databus, then converts it to analog outputs for adding an aftermarket mod.
To install a radio (any radio) you will need the Metra adaptor, a mounting kit, and an antenna adaptor. Done. Takes 1-1.5 hours for a pro.
as far as GPS antenna, you can put it on the metal just behind the VIN in the front window. That panel with the Defroster opening it it, pops up (not completely) but enough to put the GPS antenna in, as well as an XM antenna. just less distance to run wires. Either spot will work.
FYI if your installing an AVIC product into a 2nd vehicle (pulled out of 1st vehicle) make sure you reset your setting in MENU-SYSTEM SETTINGS-HARDWARE-CALIBRATION, or your speed pulse will be way off, and GPS wont work properly.
good luck
Wolfz23
