bad antenna?
By mazz303 · Mar 03, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,062 views
Posted Mar 03, 2008 · 18:32 UTC#1
For about a week my arrow would move and then all of a sudden veer off into no mans land. The connection status said NOK and showed now satelites. Now, the arrow doesn't even move at all and is stuck in one location. Could this be from doing the bypass? The clock still works fine.
Posted Mar 03, 2008 · 19:29 UTC#2
No, the bypass wouldn't cause that. Check to see if the antenna connector has come loose from the back of the unti and that the antenna is mounted where it can get a signal...
Posted Mar 04, 2008 · 12:23 UTC#3
Sometimes if you have things racked up on top of you dashboard signal will be blocked...
Posted Mar 04, 2008 · 16:50 UTC#4
ordered a new antenna. Had the it tested and it wasn't working. Not bad, been working since 2005
Posted Mar 04, 2008 · 17:03 UTC#5
3 years is a pretty good run, I'd say.
Posted Mar 06, 2008 · 06:57 UTC#6
i'm wondering if maybe mine is bad now because i just transferred the radio from truck to truck and it doesn't work all of a sudden (nav) but my clock does!
how did you order just a new antenna?
Posted Mar 06, 2008 · 07:50 UTC#7
You can order replacement parts over the phone (the number's probably in the owner's manual) or here:
http://parts.pioneerelectronics.com/
Posted Mar 06, 2008 · 18:33 UTC#8
that was exactly what i did, i ordered it online. should be here monday!
