D3 doesn't like speed changes
By brack36 · Mar 04, 2008in Problems/Troubleshooting💬 10 posts👁️ 1,339 views
Posted Mar 04, 2008 · 04:00 UTC#1
Hey, I'm new to GPS so this is probably a stupid question. I just installed my D3 and everything works. 8 satalites and one green bar most of the time. The beep to speed is changing tune with speed, so my VSS wire is good.
When I make sudden changes in speed the D3 lags behind in response. If I take off from a stop the D3 gets a good bit behind. and when I stop a bit to quickly, the D3 goes right into the intersection before stoping. It's gonna get hit! :lol: . Ok, that was retarted.
But anyway, I'm just wondering if this is normal, or is my D3 drunk?
Aside from speed changes, it works great.
Posted Mar 04, 2008 · 04:37 UTC#2
How many miles do you have on it? It does take time to calibrate completely
Posted Mar 04, 2008 · 12:05 UTC#3
Not many at all. Maby 50. Did you have this problem when your's was new?
Posted Mar 04, 2008 · 17:16 UTC#4
Ya. You can check it under the hardware info section in the navi menu
Posted Mar 04, 2008 · 19:26 UTC#5
Ok, thanks for the help.
Posted Mar 09, 2008 · 05:29 UTC#6
i have had that issue on some chevys u have to go 30 or below for it to go into 3d hybrid.Now jus cause it makes the noise doesnt mean u always have the right wire.U may need a wheel speed sensor.What make and year is your car....
Posted Mar 09, 2008 · 15:49 UTC#7
It's a 2006 grand prix. I've noticed that below 7 MPH the beeps stop. In the manual it says that some cars don't produce a speed signal at low speeds.
Driving through back roads with a lot of stop signs is where I see the lag the most, so I'm guessing this is the problem. It it very accurate on the free ways.
Is there a way to tap into the tire speed, or is there something I need to buy? I've read about a speed pulse generator. Is this what your talking about?
Posted Mar 10, 2008 · 05:02 UTC#8
Dark Green wire at the the radio harness in the C2 connector should be your speed sense wire.If not use speed pulse generator from rostra or wherever u can find one.I can get the part number from work if u need it.
Posted Mar 16, 2008 · 20:20 UTC#9
Thanks for the help man. I'm just going to try dissconecting the vss wire completely. I haven't read any complaints from people who arent using it. If this dosn't work out I'll give a speed pulse generator a try.
Posted Mar 16, 2008 · 23:23 UTC#10
I drove around for about 10 minutes with the VSS disconected, drove home, and hooked it right back up. HUGE performance degredation. I can deal with a little low speed lag.
