I have a question that I hope someone here can help me with. When using a factory GM 2 wire XM antenna (green and yellow) and plugging this into a Pioneer 920xm module, which is a single plug (pink). I plug in the yellow connector which is the satellite reception it should work right? What about the terrestrial antenna plug (green), will I loose XM in cities with tall buildings?
My other question is has anyone ever tried to splice the 2 wires from the factory antenna together and then solder these to the antenna wire that plugs into the module? In theory it should work since the module will be reading terrestrial and satellite but does the module read terrestrial? I know I can solder the XM antenna and get it to work since I have fixed them before when cut.
