Speed Sensor Needed?!?!?!
By xoliex · Mar 04, 2008in Problems/Troubleshooting💬 7 posts👁️ 1,323 views
Posted Mar 04, 2008 · 20:51 UTC#1
i have a 06 f150 king ranch and i didn't hook up that pink wire. it was hooked up on my sport trac. on my sport trac, i had a toggle switch for the emergency brake lead and the speed sensor hooked up. however the mute wire was where it was suppose to. whenever i started driving the DVD would stop showing on the screen. i did the mod i found on here and it works. thanks!!!
however, since i got the dvd working while moving, can i hook up this speed sensor wire? or does it play into the safety thing for the dvd to stop playing?
isn't it only needed for time arrival for the nav and vehicle dynamics? i'd like to hook it up if its got to do with the nav time arrival though.
i believe there should be something there on the harness because there are much more than just radio wires behind the stock radio harnesses. my truck will lower the volume whenever i hit the brake after cruising!
i've heard a speed sensor wire can be behind the factory radio.
could somebody help me find a speed sensor wire on my 06 f150?
Posted Mar 05, 2008 · 03:57 UTC#2
Yes you can hook up the vss wire and it wont affect the playback of dvd ,im not sure where your vss is but ima gonna try to find out from a buddy with the same truck
Posted Mar 05, 2008 · 05:41 UTC#3
thanks man, please let me know so i can take into that son of a gun!
Posted Mar 05, 2008 · 13:33 UTC#4
speed sense should be grey/black in the radio harness. no it wont affect your bypass. as far as if you need it or not, if your car doesnt have on, you can get away without it. but if it is accessible, i always hook it up. it just makes things a little more accurate
Posted Mar 06, 2008 · 06:53 UTC#5
do you know its this wire for sure? do you have the same vehicle? i guess i'll give it a try!
now i just gotta figure out why my voice commands ain't working, actually i think my whole nav isn't!
Posted Mar 06, 2008 · 15:01 UTC#6
I bought a Z-2 and can not access most commands, even in park, unless I have my parking break on. What tread talks about this problem. I am new and can not seem to find it. :oops:
