avic d3 install problem
By intgrakid88 · Mar 05, 2008in General💬 3 posts👁️ 669 views
Posted Mar 05, 2008 · 00:26 UTC#1
i just got my d3 and everything seems ok but when i change from radio to cd mode there is no noise coming from the speakers(i can see the counter on the cd going ) and when i use my ipod connected with the direct wire i hear the sound coming from the ipod headphones and not the speakers ....the h/u is in my 06 rsx type s using a oemII device from crutchfield in order to retain my oem bose system :cry:
Posted Mar 05, 2008 · 00:48 UTC#2
You most likely used your power antenna wire to turn on the amp instead of the remote turn on wire. Go into SYSTEM SETTINGS in the menu, Select AUTO ANT, and switch it from RADIO to POWER. Should fix your problem.
Posted Mar 05, 2008 · 01:50 UTC#3
thanks man ill give it a try i hope it works
