Hey, I just recently purchased a Avic D3, and I was wondering if I could use an alternative to soldering for the install such as crimps?
I bought the wiring harness and I heard some people solder the wiring harness onto the other wires, this probably can be done by using crimps if I'm correct.
However, on the Pac SWI-PS I would need to remove the white wire from pin 7 and put it before the resister (closer to the harness) then the resister then pin 8 wire after the resister...
so my question is can this be done without soldering?
