Difference in sound levels, radio vs iPod
By tractors4u · Mar 06, 2008in Problems/Troubleshooting💬 12 posts👁️ 1,315 views
Posted Mar 06, 2008 · 14:55 UTC#1
When I am listening to the iPOD through my D3, it will go pretty load. When I am listening to FM or XM, I can crank it up all the way and it is barely loud enough to drown out the road noise. Any suggestions?
Posted Mar 06, 2008 · 15:11 UTC#2
Well if you're using an external amp, turn up the level so the FX/XM is at the volume level you want the system to be at. Then switch to the ipod source, Use the SLA (source level attenuation) to turn down the ipod source to match the other audio sources.
If you're not using an amp, there's not really anything you can do to make the D3 any louder. But the SLA thing mentioned above will at least balance it so all the audio sources are at the same volume level.
Posted Mar 06, 2008 · 15:36 UTC#3
I have the factory Bose system with factory amp. It is in a 2007 Chevy Silverado.
Posted Mar 06, 2008 · 15:36 UTC#4
Posted Mar 06, 2008 · 15:38 UTC#5
You probably need to go in and customize your equalizer settings. Have you tried that yet?
Posted Mar 06, 2008 · 15:42 UTC#6
Yes, I have tried adjusting the EQ. This weekend I am going to pull the head unit out and verify that I have the remote turn on wire connected to turn the amp on instead of the power antenna wire. Not sure that it matters, but I need to do something. When I first got the stereo, I recieved the wrong GMOS adaptor. The stereo worked, but my OnStar didn't. When I had that set up, the stereo would run you out of the truck. Now it won't.
Posted Mar 06, 2008 · 18:19 UTC#7
Adjust the SLA, its in the sound settings menu
Posted Mar 06, 2008 · 18:55 UTC#8
Yeah, do the source level adjustments, but you'll need to go backward with the iPod SLA...down to the lowest negative setting. You cannot adjust the radio to be higher...that's the comparative threshold for the unit. You'll also need to adjust any other sources as well.
Posted Mar 06, 2008 · 21:19 UTC#9
Yes, I have tried adjusting the EQ. This weekend I am going to pull the head unit out and verify that I have the remote turn on wire connected to turn the amp on instead of the power antenna wire. Not sure that it matters, but I need to do something..
I'm sure HiFiSi will correct me if I'm wrong, but I believe you can switch this on the D3 via the user interface (settings) instead of rmoving the the unit from your dash. Check your manual.
Posted Mar 07, 2008 · 05:04 UTC#10
Am I that predictable?
Anyway, Here's how to make the antenna wire put out constant power to the amp turn on circuit..
Posted Mar 07, 2008 · 07:00 UTC#11
At least you didn't correct me. woohoo! :lol:
Posted Mar 07, 2008 · 13:04 UTC#12
Thanks everybody.
