Searching by address Question?
By dgilling0714 · Mar 06, 2008in General💬 9 posts👁️ 1,017 views
Posted Mar 06, 2008 · 23:42 UTC#1
So when you try to select your destination by plugging in an address I start plugging in the address and it does this auto address thing where it trys to fill in what it thinks i'm going to type and 9 times out of 10 it wont find the street in the same state as me or anywhere for that matter? or it will fill in before i'm finished and i can't write the correct street. is there a way to turn that thing off so i can just manually plug everything in?
Posted Mar 07, 2008 · 00:26 UTC#2
Nope. If it plugs in a street before you finish, it was the only possibility that it knew of. FWIW, I've never had it NOT know a street I needed.
Posted Mar 07, 2008 · 01:37 UTC#3
^ +1
I've had it happen to me before. D3 wouldn't let me put in the full name of the street. Then, I looked it up on mapquest, found out I had the name wrong.
Posted Mar 07, 2008 · 02:58 UTC#4
Ya, ive never had it NOT guess the street name correctly.
If you're in a relatively new area, that could be the problem.... or maybe youre using the wrong disc??? :wink:
Posted Mar 07, 2008 · 04:47 UTC#5
Do you have it set to look in the correct zone of the country?
Posted Mar 07, 2008 · 04:55 UTC#6
Try entering in the city before entering in the street name.
Posted Mar 07, 2008 · 07:58 UTC#7
I think i might have over looked the zone detail. Dang it now i feel like an idiot. How do you correct the zones?
Posted Mar 07, 2008 · 08:24 UTC#8
Press POI search or Vicinity Search. You will see a little icon that looks like a map of the US. Touch that and you can select whatever region you're in
Posted Mar 07, 2008 · 13:36 UTC#9
Check the spelling on the street you want. Last week I needed to so a service call at a customer's house on callaway st, but I kept typing in calloway (the normal spelling). It's a long shot, but it may help.
