Problem Installing AVIC D3 in Chrysler 300 2007
By machine463 · Mar 06, 2008in Problems/Troubleshooting💬 11 posts👁️ 1,456 views
Posted Mar 06, 2008 · 23:48 UTC#1
Here is my problem
First I did the by-pass on the AVIC D3
I have in the car the Boston accoustic with 8 speaker with OEM amp
I have the metra CHTO-01 harness for my car I did hook up all wire IAW the instruction except for the mute and parking brake which I left unplug because of the Bypass mod done on the radio
Now here is my problem
1. There is no sound coming of the deck but everything else work fine
2. The Deck is always ON even with no key in the ignition
Any help will be gladly appreciated
Thank
Steve
Posted Mar 07, 2008 · 00:23 UTC#2
as far as the sound problem goes, you need to call metra and get the info about an update that needs to be done they will give you the contact number and website for the guy. you then get the update cable hook it up to the pc and it will work.
the unit not turning off means the acc wire is not shutting down properly. easiest is to connect it to the switched cig lighter. if your car doesnt have it then go to the ignition and use the pink/white ignition wire(its thin like 18 gauge)
Posted Mar 08, 2008 · 22:49 UTC#3
I just order a new Metra harness I will let you know next week how everything when with picture
Do I did anything else to have my control on my steering wheel to work or just the metra harness is good enought
Thank you for the info
Posted Mar 08, 2008 · 23:34 UTC#4
there is also a volume adjustment knob on the chto-01. did you try that?
Posted Mar 09, 2008 · 00:15 UTC#5
Yes and there still was nothing coming from the speaket at all
Do you know if the metra harness keep the wheel steering control to work?
Posted Mar 09, 2008 · 02:07 UTC#6
no, you need a pac swi-ps and probably a pac swi-can as well
Posted Mar 09, 2008 · 02:38 UTC#7
I have a Dodge Charger. Get the Pac harness. They also make steering wheel harnesses that plug right in to the harness.
Posted Mar 09, 2008 · 03:31 UTC#8
Is that mean on the top of the metra harness I need two other device to have my steering wheel control to work
Posted Mar 09, 2008 · 04:35 UTC#9
peripheral-CHYAH05 Product Features
Accessory 12V, parking brake, reverse, parking light and VSS output
PESWICAN will interace with the CHYAH05
Did one at work today 45 minutes with 3d hybrid.....
Misfits products are the same I believe jus by pac same company....
Posted Mar 10, 2008 · 10:27 UTC#10
So basically if I want to have my steering wheel control I need to buy the PESWICAN and that will fit with my Metra harness or do I need do buy both the PESWICAN and the peripheral-CHYAH05
Thank for the info
Posted Mar 11, 2008 · 01:08 UTC#11
So basically if I want to have my steering wheel control I need to buy the PESWICAN and that will fit with my Metra harness.
Yea but u can also buy a piece from metra thats the same thing as a piswican---I think its a ASWIPS.
