Where to put the GPS antenna?
By ugadawgs311 · Mar 07, 2008in General💬 9 posts👁️ 1,473 views
Posted Mar 07, 2008 · 20:11 UTC#1
I have a 2003 Tahoe, and I am trying to find a good place to put the antenna. I would prefer to keep it somewhere inside the vehicle if possible. Any ideas?
Posted Mar 07, 2008 · 20:42 UTC#2
In the center or corners of the dash on the metal pad that it comes with
Posted Mar 07, 2008 · 20:44 UTC#3
or under the dash itself
Posted Mar 07, 2008 · 20:55 UTC#4
Can I tuck it away behind the unit beneath the dash?
Posted Mar 07, 2008 · 21:22 UTC#5
Plenty of people on here have gotten crappy reception under the dash. Some cars it works fine, others it won't
Posted Mar 07, 2008 · 22:23 UTC#6
I have mine under the dash, and its been fine. Make sure you either mount it on a metal surface, or use the provided metalic sheet and try finding a spot as high as possible and with as little obstruction above it as possible.
Up to you tho. I figured it'd be a pain to run the wire up through the dash so i chose not to go that route.
Posted Mar 10, 2008 · 17:35 UTC#7
velcro it on the top in middle of the dash.
Posted Mar 10, 2008 · 18:52 UTC#8
i have a 2004 yukon and its pretty much the same thing as the tohoe,
i have mines under the dash on top of a peice of metal and it gets 8 sats most of the time and i have no problem, but i did have to take my dash apart, but it was not to bad to do.
Posted Mar 10, 2008 · 20:12 UTC#9
What does the metal plate do? I didn't use mine and I still get 6-7 sats most of the time. :?
