Removing Screen..Touch panel
By RollaOne · Mar 09, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,209 views
Posted Mar 09, 2008 · 00:14 UTC#1
Has anyone tried removing the screen from an AVIC Z1, i need a little guidance
thanks
Posted Mar 09, 2008 · 01:29 UTC#2
Download the service manual. I'm mirroring a copy on my site here: http://www.inferno999.com/gps.html
Use pages 231-233 to remove the face
Use page 23 to dismantle the face from there
Posted Feb 11, 2009 · 04:02 UTC#3
Hi, im also in need of the service manual also for the Z. I need to remove the screen, I checked ur site but it's not there anymore. If u can I will be very greatful
Posted Feb 11, 2009 · 04:05 UTC#4
Posted Feb 11, 2009 · 16:04 UTC#5
Just hit the eject button to lower the screen, like you were to put a CD/DVD in... Then turn off the power... unscrew the two bottom screws on the side of the screen that connect it to the metal rails... then take the small cover on the head unit, that is behind the screen, off.... lift the tiny little tab that crimps the orange cable, straight up, and pull the cable straight out... then you can kinda tilt the screen sideways to get the screen's top two rollers out of the track, and it should come right out....
