I Have a Pioneer AVIC N4 that I will be putting in a 2003 Saturn Vue with Auto trans and 3.0L V6. I have a wire diagram but can't figure out where to hook the speed pulse or VSS. The diagram shows the right front wheel speed sensor with a TAN wire And dark green wire they are going to a wheel speed signal conditioner module. the module has black ground a white wire going to the ECM and a pink wire from the fuse block. What I can't figure out should it be hooked to the White wire going to the ECM the Tan wire (A) or dark green (
going to the wheel speed signal conditioner module.
Posted Mar 10, 2008 · 03:57 UTC#1
