RESET OF N2??
By AMTEXX · Mar 10, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,476 views
Posted Mar 10, 2008 · 22:51 UTC#1
I can't get my unit to work correctly. (ie it thinks I'm moving now and won't let me type in an address)
Any idea how to fix that? Any reset in the front of the unit?
Posted Mar 11, 2008 · 03:58 UTC#2
There is a reset hole about the size of a ball point pen on the faceplate
Posted Mar 11, 2008 · 05:21 UTC#3
what does it do to the unit? Will I have to put in the clock time etc? does it reset my save preferences or anything?
Thanks in advance
Posted Mar 11, 2008 · 07:08 UTC#4
The time is acquired from the satellites. You will lose all your audio settings, presets, etc. Basically everything except your nav address book, the 'home' button, and the 'go to' button
Posted Mar 11, 2008 · 13:04 UTC#5
Do you think that will solve the problem I'm having? What would you do?
Posted Mar 11, 2008 · 17:47 UTC#6
I would hook up your VSS wire and clear out your settings in the connection status screen
Posted Mar 11, 2008 · 18:19 UTC#7
I wish I knew how to do that. I had it installed and can't even get behind my dash. I guess I'll have to try the reset first. It's just strange though that it just stopped working. (I've had it since new and it's been 3 years!)
Posted Mar 25, 2008 · 02:55 UTC#8
Okay, finally fixed it! Reset the thing which worked well, then I noticed that I had one of my toggle switches off (that makes it think the park. brake is on, etc...etc...) Let's just say I'm an idiot! That's all it was!~
