New project!
By installermarc · Mar 11, 2008in General💬 10 posts👁️ 1,218 views
Posted Mar 11, 2008 · 02:51 UTC#1
OK. The boss was really nice to me this year, and bought (for me to play with and build) a 2008 Mustang Shelby GT500. I'm in the process of peicing this thing together (between regular installs) and have the Z2 in the dash. Problem is, I cannot seem to find the VSS anywhere. I have been at the Ford dealer pouring over schematics, and the only place I can seem to find anything close is from the wheel sensors going to the ABS system.
1- Has anyone done a Nav install in one of these cars? Please don't say "It's just like the GT and its bla bla in this connector" because all os the GT wires I have seen DON"T WORK! If you have, where did you find the VSS and what color was it (even a pin location if you know)
2- If I do end up using a wheel speed sensor wire, will it throw the Z2 off when we do a burnout or spin the tires in this thing? If so, should I connect it to the front?
As this car is going to be the store demo car, it won't get driven much, but when we do, I want it to be as accurate as it can be.
Thanks in advance.
Posted Mar 11, 2008 · 03:03 UTC#2
You might have better luck on the Mustang forums, I'm sure there has got to be some people over there that have nav units installed.
Posted Mar 11, 2008 · 11:10 UTC#3
Don't worry. I have a question posed om ModdedMustangs already. I just like to use all the resorces available to me, this wonderful forum being one of them.
Posted Mar 11, 2008 · 12:27 UTC#4
I like the way ya think. ;)
Posted Mar 12, 2008 · 18:22 UTC#5
bump. No one?
Posted Mar 13, 2008 · 00:00 UTC#6
you might be out of luck on that one. in my own experience on newer fords, those wires to the abs module dont give you what you need either
Posted Mar 13, 2008 · 16:59 UTC#7
GPS here we go!
Posted Mar 13, 2008 · 17:05 UTC#8
anyone here have experience installing cruise controls?
basically on cars that dont have vss (like the gt500) you can get a magnet sensor and add it to the drive shaft. now how easy that will be i couldnt tell you
good luck
Posted Mar 13, 2008 · 22:43 UTC#9
Not so sure about anything getting attached to the drive shaft, as the car's top speed is close to 190, and we plan on a TON of engine/suspension/brake work to make it a bit faster.
Posted Mar 19, 2008 · 03:36 UTC#10
Joy! After much looking, and going over the car's wiring diagram at the Ford Dealer, I found it. For future referance, The VSS on the Shelby GT500 is a Dark blue/yellow wire at the ECM, the harness runs under the power distribution block and SHOULD be the only blue/yellow wire in that harness.
