2007 Altima Illumination wire connection
By azpt · Mar 11, 2008in Problems/Troubleshooting💬 3 posts👁️ 704 views
Posted Mar 11, 2008 · 20:18 UTC#1
Which wire does the illumination wire from the Avic go to?? I've red both the the red/blue and the red/yellow off the Altima vehicle harness..... which one is it? What is the best way to connect the wires.... t-tap??
Posted Mar 11, 2008 · 20:28 UTC#2
I don't have the specific pinouts for your car, sorry.
If it were me, I'd bust out my voltmeter, hook one lead to vehicle ground (metal bolt works fine), and the other to one of the suspected wires (red/blue for example). Flip the headlights on or off and see if the voltage changes. If it does, you've found which wire is signaling headlight status, and connect it to the illumination wire coming from the AVIC.
To connect it, I'd recommend soldering and insulating with electrical tape (or better yet, shrink tubing). But if you don't feel comfortable with that, a tap is just fine.
Posted Mar 17, 2008 · 18:39 UTC#3
fyi.... worked fine when i tapped in to the red/yellow wire. pin #8
