New D3 install
By c6user · Mar 13, 2008in General💬 11 posts👁️ 1,527 views
Posted Mar 13, 2008 · 01:06 UTC#1
Question I am getting ready to install a D3 in my 07 corvette. My question is this. I am installing a backup camera as well. How can I activate the backup camera at anytime. I know the hack will allow me to watch dvd's while driving and nav while driving. But what about looking at the backup camera.
Thanks.
Posted Mar 13, 2008 · 03:47 UTC#2
You can select "rear view" for navigation mode. That will show your camera and a smaller nav screen.
Posted Mar 13, 2008 · 13:35 UTC#3
Or you can just plug the rear camera video into the AV2 input and use it just like any other video input and switch to it in full screen at any time.
Posted Mar 13, 2008 · 13:38 UTC#4
Yeah, while in NAV mode, press the button below "MAP" button on the left-side of the unit and select "Rear View" as withinavoid suggested.
Posted Mar 13, 2008 · 19:40 UTC#5
HiFiSI, about the rear view camera. I will be installing a Avic-D3 into my new GMC when it arrives. I tow a 5th wheel trailer with a rear view camera so I purchased a new color camera that is compatible with the D3. If I wire it in directly to the back of the D3 can I just go to camera and get a full screen? Or is it best just to plug it into the front of the D3 in the A/V input? The front plug-in sounds a lot easier.
Posted Mar 13, 2008 · 20:25 UTC#6
The front AV input and the rear AV input both do the same thing. You just run the RCA video cable to either of them, and when you select AV1 or AV2 as your source, the rear view feed should show up full screen. You just have to wire the rear view camera to a switched power source so it's not on them the truck is.
Posted Mar 13, 2008 · 22:13 UTC#7
i got a back up camera on my truck and it turns on when i put the truck in reverse......how do i turn it on while i drive??? i tried pressing back up camrea on the thing in menu and it just turns to a blak screen with the back up camera warning
Posted Mar 13, 2008 · 22:17 UTC#8
i try selecting rear view from nav mode and it just shows a black screen
Posted Mar 13, 2008 · 22:35 UTC#9
Check to see that the camera is powered by a wire that has power when the car is on. If you have your camera powered by the reverse wire in your car, the camera will only be one when the car is on reverse.
Posted Mar 13, 2008 · 22:50 UTC#10
damit im pretty sure thats what it is.....oh well i dont really care to use see out the back while i drive lol
Posted Mar 14, 2008 · 01:28 UTC#11
Thanks for the reply's guy. So I assume if i run the power of the backup camera to the aux power and plug it into the av2 video input then i will be able to see the car that my vet just spanked :lol: . Is this right.
