2001 Honda Accord Sedan
By telmnstr · Mar 13, 2008in Vehicle Specific Wiring💬 2 posts👁️ 1,011 views
Posted Mar 13, 2008 · 03:27 UTC#1
Okay, this is a bit odd. I know the VSS wire is blue with a white stripe. I searched and found that it appears on a connector on the ECM / ECU that is grey.
There is a blue w/ white stripe lead in the driver side fusebox on the side... but that doesn't seem to carry any sort of PWM signal (My meter has a frequency counter function on it).
But... I can't find the ECM. On the passenger side floor, under trim on the right side (near the passenger door) there is an electronic module but it doesn't match the ECM pictures I see on feeBay. I haven't poked at it much yet because it doesn't seem to match the reports of ECM location (And the plug count looked to be 3, not 4 like the ECM is rumored to have).
I read that it's in the lower center console accessible by pulling up the carpet on passenger side... but I don't see any modules there... That is where I have the BT adapter, and I had other components there before.
My car is V6, auto tranny. I found that old Accords had them on the floorboard straight in front of passenger but that didn't look to be the case either.
On another note, I have the steering wheel controls hacked to directly drive the D3 with _no_ interface needed. I am going to write that mod up for everyone.
In the meantime... My pink wire dangles!
Posted Apr 16, 2008 · 15:14 UTC#2
Speed Sense = BLUE/WHITE
PCM MODULE IS LOCATED UNDER CENTER OF DASH, AUTOMATIC TRANSMISSIONS GRAY PLUG PIN #9, MANUAL TRANSMISSIONS BLUE PLUG PIN #23
Found this
