Everytime I get in my car with my phone a message pops up (on the phone) asking if I would like to bond with the Pioneer BT unit. I select yes and it ask for a code I put in 0000 but that doesn't work. Anyone with the RAZR have this problem. If so please advise.
BlueTooth and Razr v3
There is a setting in your phone that you need to change. You need to change is from "Always Ask" for authentication to "Never ask" or "Ask Once." As for the code, try anything else generic, or you may have changed it to something personalized
mine did this. i changed it to always connect and put in the 0000 code and it works fine now.
Anyone get BT audio to work with the razr2? I run Sprint and cannot even get it to connect.
I finally got it to work. I went in and changed my PIN on my D3. I guess it wasn't set to 0000. Put in my new pin and all is good. Just FYI if you didn't know when sending you phone book; go under share contact. I was looking for send or forward for awhile. Thanksagain for all the help
Did your radio download the address book? What version are you running on your razr?
thanks
Had to go 1 at a time. Put in like 40 contacts in about 10 minutes.What do you mean by version ....the phone ?
I was referring to the firmware on the phone. I been looking on the web and depending on the version some features may work. Did you autoconnect work ok?
Yep. Everytime I get in the car the phone ask if I would like to connect to the Pioneer Bt-200
Change your phone to "Never ask" like I mentioned many posts ago
What ^^^^ said. I've got a V3xx and it links every time b/c I set the permissions as he mentioned.
thanks alot, i'm going to switch my samsung gleam back with my old razr
