THE THING EVERYONE KNOWS EXCEPT ME.
By sadbut99 · Mar 14, 2008in General💬 6 posts👁️ 1,565 views
Posted Mar 14, 2008 · 23:46 UTC#1
Hi.
i'm just installing z2 through gmos-lan-02 and thinking disconect dimmer wire.
I set the headlight switch on auto mode. it usually on even in daytime.
Can i diconnect illumination wire and control the dimmer as the time running on the z2 software system?
Posted Mar 15, 2008 · 18:18 UTC#2
um can you repeat the question, in english maybe?
Posted Mar 16, 2008 · 01:14 UTC#3
Sounds like you want to know if the day/night mode can be controlled automatically, based on the current time?
Nope. There is no output based on time.
Posted Mar 18, 2008 · 11:50 UTC#4
Turn your headlights on manually?
Put the dimmer wire on a switch so you can dim it whenever you want.
Posted Mar 28, 2008 · 06:15 UTC#5
The problem you are having is your Daytime Running lights are coming on, and thus outputing 12 to your dimmer wire on your Pioneer, which is putting it in night mode.
Couple of options.
1- disconnect it completely
2-Leave it connected, but put a toggle switch on it to "disconnect" it during the day
3- Try connecting the Dimmer wire from the ZX to the HEADLIGHT wire in the car, NOT the DIMMER/ILLUMINATION wire in the car.
The dimmer/ill wire is connected to the parking light circuit, which is connected to your daytime running light wire.
The headlight wire MIGHT be separate circuit, it depends on your vehicle.
SOME GM vehicles the daytime running lights, are a completely different light, and some they daytime lights are the headlights but at 1/2 power.
TO check... start your vehilce during the day when its bright outside.
get out, and look at the front of your vehicle... pay attention to what lights are on.
now go turn on your headlights, and see if its the same lights that were on before, only brighter, or a different set of lights completely.
IF they are different completely, simply connect you Dimmer wire from your ZX sieres, to the HEADLIGHT wire at the headlight Switch.
The Zx will only go into night mode when the actual headlights are on, instead of the parking lights
Good luck
Wolfz23
Posted Mar 28, 2008 · 16:16 UTC#6
Add a photo relay in series. It will allow a signal to the AVIC only when daylight is insufficient. Many vehicles have this already and the AVIC remains in daylight mode even though the lights are on. Once I go into a tunnel, the AVIC switches to night mode and then back when I exit. The lights remain on at all times. The question is where to mount the photosensor, but that's not hard.
