A lot of 06 Explorer install questions
By 20yardendzones · Mar 15, 2008in General💬 18 posts👁️ 2,155 views
Posted Mar 15, 2008 · 05:20 UTC#1
I am about to take the plunge and install the D3 with BTB200 blue tooth module as a replacement for the audiophile 6 CD with subwoofer HU in my 06 Explorer Limited. I also have the rear DVD system. I am using the Crutchfield FORD wiring harnesses.
The Crutchfield subwoofer harness has separate red (labelled woofers) and white (labelled subwoofers) RCA ends plus 2 blue/white stripe wires. The wiring instructions label the wires as amplifier turn ons. The D3 has only 1 blue/white on the power harness.
Question 1 - Do I plug both red and white RCA plugs on the Crutchfield harness into the into the subwoofer output on the D3 harness or are they two separate items with dedicated blue/white power wires?
Question 2 - If I do plug both red and white RCA plugs into the D3 harness, should I solder both blue/white wires from the Crutchfield harness to the single blue/white wire on the D3 harness?
The BTB200 module has a yellow power and black ground wire.
Question 3 - Can I solder these two wires to the matching wires on the Crutchfield harness? Will this overload the fuse or cause feedback issues with the phone?
I want to to the bypass option for "on the go" nav changes. Can I ground the "moved" mute wire and the brake wire by soldering a wire to them and then to the ground on the Crutchfield harness?
I am adding the pac swi-ps steering wheel controller.
Question 4 - Can I connect the red wire and ground to the matching wires on the Crutchfield harness as well?
Finally, I am adding the PIE DVD unit to allow me to listen to the rear DVD system on the Explorer's speakers.
Question 5 - Can I connect the red wire and ground to the matching wires on the Crutchfield harness too?
Sorry for all the questions and thanks in advance for any advice.
Posted Mar 15, 2008 · 19:06 UTC#2
yes to all, but you need a 3k ohm resistor between the blue/white from the avic and the blu/white from the harness
Posted Mar 15, 2008 · 19:45 UTC#3
Thanks for the quick reply misfit. This might be a stupid question but where would I find such a thing and what is the process?
Posted Mar 15, 2008 · 19:48 UTC#4
i guess you could get it at radio shack. just put it inline between the two wires. without it, you'll get a thump through your sub every time the avic powers up the factory amp
Posted Mar 15, 2008 · 20:14 UTC#5
I will do that - thanks again for your help.
Posted Mar 18, 2008 · 01:24 UTC#6
So I went to Radio Shack and picked up a 3.3k resistor (orange,orange,red). This might be stupid, but is this the process I need to follow to do things right
1. Solder the two blue/white wires from the Crutchfield subwoofer harness to the long wire on one end (or do I need two resistors - one for each of the wires) and
2. Solder the single blue/white wire from the AVIC harness to the long wire on the other.
Do I cut the long wires down any?
Sorry if these are dumb questions, I have never dealt with a resistor before.
Posted Mar 18, 2008 · 01:26 UTC#7
you only need one resisteor. one of those blue/white wires is usually dead anyway. you dont have to cut it, but you can if you want
Posted Mar 18, 2008 · 01:56 UTC#8
Thanks, I was worried about having to use a circuit board or something.
I wanted to plan out the wiring and components before ripping the truck apart. I don't know what I would have done without the forum.
Posted Mar 19, 2008 · 04:48 UTC#9
I hear this thump as well in my lincoln, and am about to pick up a resistor tomorrow at RS. Will this also cause my rear speakers not to work? Because they don't work right now, and I don't have anymore wires I can hook up. (Wire harness diagram has only 4 sets of speaker wire and the 4 speakers in my door works).
Posted Mar 19, 2008 · 14:31 UTC#10
The door speakers and subwoofer should be totally independent "circuits". I received two separate wiring harnesses from Crutchfied. The main one has the power, ground, lighting, door speakers, etc. The sub-woofer harness has two (red/white) RCA plugs and two blue/white power wires. This harness is to plug into the factory harness running to the subwoofer/amp unit and is connected to the AVIC. It is between these amplifier wires and the blue/white wire on the AVIC "RCA" harness that misfit suggests the capacitor is added.
As far as I know, this is what the sequence looks like:
AVIC bl/w ----- capacitor ------ crutchfield bl/w's ------Ford harness --- sub/amp
Posted Mar 19, 2008 · 16:33 UTC#11
That looks right.
on the Ford/Licoln/Mercury Wire harnesses, the Resistor would get hooked up to the blue/white wire (Amp turn-on) on the harness and the blue/white wire (Remote Control Start) from the AVIC. The RCA plug on the harness gets hooked up to one of the Suwoofer outputs on the AVIC RCA connector (Where the mute wire is located). The black/white wire (amp-ground) gets grounded wherever is convenient for you. And those are all the connections on the small 8 pin harness.
The bigger harness is pretty straight forward and hooks up pretty directly to the AVIC. Remember to hook up the AVIC's illumination wire to the ash tray lighter.
Posted Mar 19, 2008 · 16:41 UTC#12
This might sound dumb, but there was matching illumination wire on the Crutchfield harness that I was going to solder to the AVIC illumination wire. Is that correct?
Also is there a VSS on the Ford radio harness that I can tap into?
Posted Mar 19, 2008 · 23:44 UTC#13
You can do that, but then when you turn on your headlights, your AViC will not dim like the rest of your dash lights. if you want it brighter, than hook it up as normal
Posted Mar 20, 2008 · 03:28 UTC#14
Another dumb question - what happens when there is no ashtray/lighter to tap into?
Did you find a VSS wire on the harness that is related to the volume speed control?
Posted Mar 20, 2008 · 11:08 UTC#15
Speed Sense purple/orange PCM, 50 pin plug, pin 1
The PCM (Powertrain Control Module) is on the passenger side firewall. The VSS wire is also found at the windshield wiper motor
use this for illumination if the radio harness wire does not work:
Parking Lights (+) blue/white + driver kick or SJB, conn. A, pin 11
The SJB (Smart Junction Box) is part of the fuse/relay box under the driver side dash.
why would you tap into the ashtray lighter??
Posted Mar 20, 2008 · 13:58 UTC#16
Thanks misfit! I will see how the illumination works on the harness first before digging in any further. I was hoping the VSS wire would be on the radio harness as I can alter the volume with road speed.
I was really looking forward to getting things installed on the holiday tomorrow but now my wife needs to take our 5 year old and his 3 year old cousin on a road trip on Saturday and wants my truck for the rear DVD entertainment. I don't dare have it ripped half apart and run into a snag before they go.
Posted Mar 20, 2008 · 14:01 UTC#17
you may have issues integrating the rear seat dvd with the d3
Posted Mar 20, 2008 · 14:48 UTC#18
I have the PIE FRD04-DVD unit that is supposed to power the unit and allow the sound to come through the speakers through the A/V1 input on the D3. Have you used this unit before?
As long as the rear DVD unit works and the sound comes through the headphones I will be happy - the audio back through the system speakers will be "gravy" I am tired of hearing Pokemon over and over again!
I have also added a TERK A/V extention unit to the rear unit's input and run it back to the back of the center console to attach a GameCube. I could add a simple video switcher to the rear A/V output of the D3 to "complete the loop" and have the front and rear video the same.
