Being new to the Avic D3
By brunp · Mar 15, 2008in General💬 5 posts👁️ 895 views
Posted Mar 15, 2008 · 12:03 UTC#1
I have it installed in my Saab and it looks amazing. So far, I really like
the unit, but have to confirm a couple things:
1) How do I find out if I need any firmware updates? I probably can figure
out where I can get at the current version. If there is an upgrade, how do
I get it?
2) iPOD control...can you not select an artist and hit play? Do you have to
drill down to the actual song?
3) Will have to figure out how to do the bypass, where instructions should be
available in the other forum section, so no probs there. :-)
4) Where did you guys place your iPOD?
Paul
Posted Mar 15, 2008 · 14:31 UTC#2
I get it?
Don't worry about it. There are no upgrades for the D3 right now. If there is one in the works, it's at least a few months away. They usually come out yearly at the most frequent.
I don't recall exactly how you get to there through the menus because I just hit shuffle all and skip what I don't feel like listening to at the moment... But you should know that it's the SAME EXACT method as when using the actual ipod. So however you do it with the ipod, that's how it is on the D3.
3) Will have to figure out how to do the bypass, where instructions should be available in the other forum section, so no probs there. Smile
Yeah, the bypass really is a piece of cake. People make it out to be some crazy super hard impossibly complex task... but after they do it, they realize it was probably the easiest part of installing the unit. Which is kinda easy in he first place.
Glove compartment. Because I'm never going to touch it... might as well stick it somewhere out of the way.
Posted Mar 15, 2008 · 20:08 UTC#3
not going to answer 1 - 3 cause theyw ere answered perfectly before :P
4> part of the Vibes dash thing there's this littlecompartment near the floor right under the centre stuff. i have it going in there. when i close it you can't see the ipod or wires
Posted Mar 15, 2008 · 20:58 UTC#4
I assume you need to drill to get the cable into the glove box?
Paul
Posted Mar 17, 2008 · 17:31 UTC#5
Depends on the car. I have my BTB200 unit in the glovebox and there was no drilling necesary. The sides of the box open up to the inside of the dash and it was very very easy to pass wires from the console to the box
