PAC SWC
By veritus · Mar 15, 2008in General💬 4 posts👁️ 783 views
Posted Mar 15, 2008 · 15:02 UTC#1
How did you guys remove the wire from the factory SWC harness? I'm hesitant to cut that harness and put a splice in it, but I don't see a way to remove the pin. Any help would be appreciated.
Posted Mar 15, 2008 · 15:46 UTC#2
remove?
Posted Mar 15, 2008 · 15:51 UTC#3
remove?
Sorry. I meant pull the wire from the factory SWC harness. In other words, how can I connect the white (my info wire) from the PAC to the factory SWC harness? Do I need to cut the wires from the harness? or is there a way to get them out.
Thanks for the reply. I'm in the middle of the install and I'm trying to finish it up.
Posted Mar 15, 2008 · 16:17 UTC#4
no need to cut, you can tap in, or cut if you need just leave enough to put back later
