Ok, so first off, I have an AVH-P6800DVD. As you know its very similar in design to the avic units.
When run off the high level outs (speaker wires) it sounds great.
When attached to the rca's I get alt/engine whine bad.
Checked all grounds, good.
Regrounded everything, to the battery, then a common point for all items, then to just different bare metal places.
Tried the ground the rca shield trick, no go.
Even tried hooking the head unit up to a different car for power, still not good.
Also all of this was done with all pioneer accessories disconnected from the head unit to eliminate them as a problem.
Also tried ground loop isolators and no help there.
Sound goes away when the rcas are disconnected from the head unit (OR) from the amps.
I've read on here (searched for the last 3 hours) about an rca fuse ???
Never heard of one on any device with rcas.
I'm thinking maybe bad caps in the power supply of the head unit ??
HELP! I want to resolve this so I can sell it and get a d3/z1/z2 for my new ride. The p6800dvd doesn't have external remote jacks that I need for my steering wheel controls ![]()
Used to be a local installer but im stumped!
FWIW - the current setup :
97 eclipse gst spyder
avh-p6800dvd
avg-vdp1
i pod adapter
gex-p920xm
diamond audio d3400.4
diamond audio d3600.1
