2007 Altima BOYO reverse camera tap in question
By Ursus · Mar 20, 2008in General💬 12 posts👁️ 3,207 views
Posted Mar 20, 2008 · 00:48 UTC#1
Hi guys, a couple of questions regarding the BOYO VTL400 on my 07 Altima
1. Power tap: I plan to tap the camera to reverse light so that it only turns on when i put the car into reverse. But I've read that sometimes the reverse light wire itself may not have the power to supply the camera? is that true? If that's the case, is there any other wires that I can tap the camera to?
2. Input tap: is that just straight to the back of the D3? so basically just harness it from the trunk to the dash? via doorsills n' stuff.
Thanks so much, trust me I searched throughout the forum and couldnt find the answer.
Posted Mar 20, 2008 · 01:27 UTC#2
This will probably work just keep in mind that the camera will only have power when you have the car in reverse. This also might be a problem if the camera needs time to boot up or turn on. Also if you plan on using the rear view like Z2 has when going down the road will not work. For your case, probably useless for cars.
I also considered this, but I ended up running the power from the swich wire on the radio.
Hope this helps
Posted Mar 20, 2008 · 01:30 UTC#3
The camera I used was very low power so that was not an issue.
Posted Mar 20, 2008 · 01:35 UTC#4
hey k what cam do u have?
Posted Mar 20, 2008 · 01:45 UTC#5
I tapped the reverse signal for power on my Ridgeline and it didn't work. The voltage dropped from 12V to about 2V when the camera was attached.
I ended up putting it on the ignition power. The camera is on all the time this way, so I can use the reverse-view from the navigation menu if I want to.
Posted Mar 20, 2008 · 02:33 UTC#7
Thanks alot for the quick replies. Since I'm installin a D3, i guess it would be useless to tap into a constant power source; i will try the reserve light source, if that doesnt work, i will try the radio one. Thanks!
Posted Mar 21, 2008 · 18:22 UTC#8
Hi guys, i just got new info and a new question. Someone on another forum suggested using a relay? is that necessary?
The following image is for a Ford I believe
Let me see if i get this, so i can crimp the positives together and put them on a female connector, and BOTH negatvie (grounds) on BOTH top and right pins.
BUT WHERE DOES THE BOTTOM ONE CONNECT TO???
Posted Mar 21, 2008 · 19:38 UTC#9
Will this harm the camera by having it on all the time?
Posted Mar 21, 2008 · 20:41 UTC#10
I don't know what the life expectancy of a CCD video camera is these days. I'm sure that its life will be shorter because it's on all the time, but I can also check the rear view anytime (like with a trailer) because of this. It's a tradeoff I'm willing to take...
Posted Mar 22, 2008 · 18:22 UTC#11
anyone know what the bottom pin of the relay connects to? help~
Posted Mar 23, 2008 · 01:55 UTC#12
You're better off just wiring the camera to ignition power. If you're intent on wiring a relay off your reverse lights, then here's the RIGHT way to do it in an altima.
30 - to + wire of backup camera
87 - to + 12volts ignition or constant don't matter just has to be capable of supplying enough current to power the camera.
85 - to ground
86 - to reverse wire in car.
