euphoria said:
hi,
if ducatiboy circuit is installed than can we also change the navigation location or destination while in motion as some people write that you can select a different location unless you stop the car and pull the handbrake and than select again a different location. any feedback will be highly appreciated,. thanks
Yes, you can do anything while in motion... absolutely everything. There is a feature where you can change the location, this corrects for errors in the positioning. I wouldn't do that while moving, it will just mess up your location. Not that you can't, but it's not a good idea unless you aren't moving.
If you mean you want to enter a new destination or what ever, sure. With my circuit you can do absolutely everything the Z1 can do while moving.
