need help installing GEX-9920XM XM tunner in Z2
By rwerth7 · Mar 23, 2008in General💬 5 posts👁️ 838 views
Posted Mar 23, 2008 · 18:35 UTC#1
Hey Guys,
Quick question for you. Where on the back of the Z2 is the connector for the IP-Bus cable coming from the XM tunner? The connector on the cable is blue. I can't find any connector on the Z2 that mates with that connector other than for the one I'm using to connect my IPod adaptor.
thanks in advance for any advice.
Posted Mar 23, 2008 · 18:53 UTC#2
The correct model number of the XM tunner is P920XM
Posted Mar 23, 2008 · 19:34 UTC#3
You daisy chain them together. Run it to your ipod adaptor
Posted Mar 23, 2008 · 20:18 UTC#4
If you daisy chain tthem together does the Z2 still "see" the Ipod and the XM tunner as two separate sources?
Can you toggle between the two in the AV Source Menu screen?
Posted Mar 23, 2008 · 21:15 UTC#5
Yes, you can run dozens of accessories/sources by chaining them together, thats why that all have an IN and an OUT. The bus cable will detect what it is through the cable and they will all show up in the source menu
