2003 Chevrolet Silverado Ext
By speedingstang38 · Mar 24, 2008in General💬 5 posts👁️ 1,062 views
Posted Mar 24, 2008 · 22:54 UTC#1
I just bought an avic d3 that should come in a few days and I want to be prepared for my 2003 Silverado I bought the peswips steering control module and axxess gmos-04 integrated harness, does anyone have a heads up before I dig in, also I have read that you don't have to find the vss and reverse when using the gmos-04 is this true or does it not apply to my truck. Any info is appreciated. Thanks in advanced.
Posted Mar 24, 2008 · 23:35 UTC#2
Have the in-dash install kit (the bracket that holds the radio and provides a trim cover)?
On my 07 the GMOS-02 kit had the VSS and reverse I think.
Posted Mar 25, 2008 · 16:28 UTC#3
I've got the GMOS-01 for my 06 Impala SS and it's not getting/passing the VSS signal for some reason. It does, however, handle the reverse. I've also got the SWI-PS SWC module and it's a PITA. I may have gotten a bad one, but when I talked to PAC, they instructed me to wire in a small capacitor between a couple wires and even that did not help.
Search around for other threads about the GMC/Chevy 2500HD installs. There is a quirk or two that may apply to you regarding illumination hookup issues.
Posted Mar 26, 2008 · 00:33 UTC#4
My dimmer doesn't work in my truck either, the install guys took my dash apart again after the first test and couldn't get the dimmer to work, so I told em f-it cause at that point I had been waiting 3 1/2 hours.
Posted Mar 26, 2008 · 23:07 UTC#5
I have on 03 silvy too. The VSS wire is the green with white stripe behind your instrument cluster. My auto dimmer didnt work either so I had to tap into a wire over at the connector where the headlight switch is. I forget which wire though- I wanna say it was brown but I think there was 2 brown ones. I had to cut a little bit of plastic inside the dash near the bottom cause the bottom of the D3 was hitting it.
