No Sound with bypass
By benzwhere · Mar 25, 2008in Hacks/Mods💬 8 posts👁️ 1,623 views
Posted Mar 25, 2008 · 15:47 UTC#1
Hi All I'm a newbie here but appreciate all the effort and information. I've all the bypass threads but cant find a answer to my problem. I installed the unit (a D3)and did the bypass myself and all works well, I can watch video and use the nav while driving but I have no sound for all inputs! Not sre what I did wrong. Checked all my connections and the mute pin placement and condition and all looks good. Please advise. Thanks
Posted Mar 25, 2008 · 15:49 UTC#2
The bypass wouldn't effect that one bit.
Do you use external amps for your speakers or the D3's speaker outputs? Is there a factory installed amplifier you're interfacing with or not?
Posted Mar 25, 2008 · 21:59 UTC#3
No not using anything but the D3. I also found that there is no output (sound) via the head phone jack either. I tried system reset and noting changed. Really stumped now.
Posted Mar 25, 2008 · 22:59 UTC#4
what kind of car is this in? output headphone jack????? the front jack is a input.... not output. if your factory radio uses a external factory amp. that may be where your problem lies... either need to use a amp turn on or bypass the factory amp
Posted Mar 25, 2008 · 23:11 UTC#5
Ah yes an input I just read that in the manual and feel dumb. Its in a 2004 honda element.
Posted Mar 26, 2008 · 18:35 UTC#6
i would suggest making sure u didnt ground the mute wire, while its still in the mute wire location.
I did this by accident. I was installing a PS2, and when I took the unit out the wire came loose and I put it in the wrong spot.
Posted Mar 27, 2008 · 03:37 UTC#7
Turns out the blue wire that is for the power antennae is also the power for the preamp. So I took off the tape and wired it up and BINGO all is good and I love the flexibility of the unit. Thanks for the help and also Crutchfield with their awesome tech support.
Posted Mar 27, 2008 · 04:10 UTC#8
Not exactly... the blue wire on the power harness is for the car's power antenna or antenna booster. It is only powered up when the AM/FM radio is the selected audio source, although there is an option to change it to constant power in the settings menu.
The blue wire on the RCA/preout harness is the wire that should be used to turn on any amplifiers.
