Music library question
By openendstraight · Mar 26, 2008in General💬 3 posts👁️ 696 views
Posted Mar 26, 2008 · 03:28 UTC#1
I burned a cd off of my ITunes. I had to use two cd's to get all of the songs of the album.
My question is, is there a way for me two combine the two albums into one on the Z2. It is listing them as two.
I would like the to all be togather.
Posted Mar 26, 2008 · 15:38 UTC#2
Nope. But then, the library is more or less designed to replace a CD changer, and you can't do that there either.
Sucks, but it's easy to live with.
Posted Mar 28, 2008 · 05:49 UTC#3
There is a ghetto way to do it.
Let the Z2 rip both CDs to the library. Then when you are stopped- park brake on- go into your library, select the 2nd album, let it start playing.
touch the memo/edit/option on the screen, then edit the artist.
If you choose "select from list" then choose the artist from the 1st CD, it will name them exactly the same.
do this for all the songs on the second CD, and it will put them all in the library list as the 1st CD. resulting in both CD's being under 1 artist when you search/play it.
i do this all the time with Live songs, or songs "featuring" someone.
Just change the artist name, select from list, select whatever one you want it listed with.
Good Luck
wolfz23
