I have two Z2's. I think it depends on where you live?
One using 3D-Hybrid, and the other using Simple Hybrid.
When I drive the hills in the Atlanta, GA area... It makes a big difference.
The vehicle with the 3D-Hybrid is always right on, and the pointer stays right on the highway, regardless of Overpass's, Tunnels, etc...
In Simple Hybrid, you can loose your tracking for an instance or when you make a turn, or go down into a hole.
Based on my experience, you are far better off with having the VSS connection if you can.
3D hybrid means it tracks you
WITH 3 dimensions, not IN 3 dimensions. The GPS antenna alone is enough to determine your 3rd spacial dimension (altitude) but as it's a navigation unit, it's unnecessary and the feature is not included.
What is meant by three 3 dimension hybrid tracking is your position is tracked in 3 ways: GPS antenna, accelerometers, and distance tracking with VSS. If you're in Simple Hybrid, it just uses GPS antenna and accelerometers -- and like I've said before, this works fine for most people. It's only really necessary to use VSS if you're consistently off or not getting good GPS signal.
So don't worry about it if it's otherwise working fine.
