D3 Navigation questions
By stilmatik · Mar 27, 2008in General💬 11 posts👁️ 1,486 views
Posted Mar 27, 2008 · 04:57 UTC#1
Is it true that the Navigation DVD must be in to use the GPS? So I cant quickly switch from DVD PLayer to Navigation, I have to put a whole new DVD in?
Posted Mar 27, 2008 · 05:39 UTC#2
ya pretty much lol....thats why i use a ipod
Posted Mar 27, 2008 · 14:07 UTC#3
Yes, that's right. If you're using the DVD drive, you have to remove what's in there, put in the nav disk, and program in your route. Once the route's in there, you can rempve the nav disk again.
This is why it's pretty beneficial to install a Sirius tuner, XM tuner, and/or ipod, so you can just leave the disk in the drive all the time.
Posted Mar 28, 2008 · 03:06 UTC#4
just barely on topic:
I tried to set a route the other day and then take the disc out, but it told me the route would be lost if the disc is removed.
Do I have to do something specific if I want to remove the disc?
Posted Mar 28, 2008 · 05:53 UTC#5
I believe you have to wait a minute for it to save the route to memory.
Once the route is saved, there is a small green icon that looks like a floppy disk on the bottom right of the map display.
Then you can remove the disk.
Posted Mar 28, 2008 · 11:42 UTC#6
I thought I read in the instructions somewhere that the route has to be no more than 15 miles???
Posted Mar 28, 2008 · 13:01 UTC#7
That's the first I've heard mention of that... I know I've input routes that were over 15 miles long. But then again, I leave the nav disk in the drive all the time, so I don't know whether or not it actually saved the route to memory.
Posted Mar 28, 2008 · 13:26 UTC#8
Nope. If you store a route more than 75mi, it will store the length by a 6mi cross section, so if you miss a turn, you've got 3mi in either direction for the unit to redirect you to the original route. If it's less than 75mi, the route is stored length by 10mi across.
I don't know how it works when you plan a route across two zones (on two discs) but if you're driving that long and cannot spend 30s to reload the new disc, you are a music addict and need help. :lol: However, if you cross a border frequently, that might suck.
What you saw about 15 mi is the "home zone"...and I think it's actually 10mi x 10mi square. Once you insert the disc and set your home zone, it will remember that indefinitely, so if you need your local area, it will always show on your map. However, drive beyond the border of that 10x10 square and you're in no-mans land (gray area...i believe) and will need the disc.
Like Si said, XM and an mp3 player are your friend.
Posted Mar 28, 2008 · 17:50 UTC#9
I have taken the disk out on routes as long as around 450 miles before. I don't think there is technically any limit. I think the odds are you would need to find a gas station or food before and need the disk, before it actually ran out of memory
Posted Mar 28, 2008 · 21:57 UTC#10
Okay, well if there is a 15 mile limit then that would explain my problem. But if people are saying it works well over that, then I guess I should try again.
The time it didn't work for me, I was going to my girlfriends house, who lives on the other side of town, and I just wanted to see how accurate it was. So getting lost wasn't a problem at the time.
Posted Mar 29, 2008 · 16:38 UTC#11
Are you planning a route, or just using GPS positioning? If you have a route planned, are you letting it store in memory before you remove the disc? You need to wait until the green box with an M in it to stop blinking.
Again, it's in the manual...pg 74-75 area.
For memory nav mode, see pg. 133
