Help: GPS Map is Not Moving (newbie)
By azote · Aug 07, 2006in Problems/Troubleshooting💬 4 posts👁️ 1,019 views
Posted Aug 07, 2006 · 13:28 UTC#1
Hello guys
I installed it my 350z yesterday... (with the hand break grounded, while the ducatis circuit arrives)
when I left my house it was working great... but after I put some gas and I tried flashing my lights when starting it stoped traking or even moving the map...
the calibrating sensors thing won't work... it always says "initializing sensor"
I'm not getting that screen that says that my hand break is not connected right anymore (event thought i'm still moving)
any help or any sugestion or guess would be great....
BTW: how can I reset it the unit?
thanks
Posted Aug 07, 2006 · 13:39 UTC#2
azote said:
Hello guys
Well, I woudln't recommend grounding the parking brake all the time no matter what. It's better to put it on a toggle switch or actually connecting it to the parking brake.
Flashing your lights with the parking brake wire grounded will not work.
I think your reset the unit idea is a good one.
thanks
I think the procedures are in the manual page 175 or so. I think the front panel reset button will be the one needed. Use the black plastic pencil that came with the unit, it's just to the right of the eject button.
What I would recommend is disconnecting the parking brake wire, and then flash your lights till my circuit comes in. OR, since I don't have any orders which haven't shipped, just wait, it should be there very soon. Just make sure when you install my circuit to disconnect your parking brake wire and reset the unit again.... until that, my circuit won't work.
Posted Aug 07, 2006 · 15:21 UTC#3
thanks Ducati.
I order it yesterday :)
let's hope that the reset fixes it ... because right now I don't need to do anything and I can change everything while driving but no gps tracking...
So let me get this strait:
If I don't connect the hand break to anything and flash my lights it will allow me to change my destination right?
cool man... thanks again...
Posted Aug 07, 2006 · 15:47 UTC#4
Not only can you change your destination, you can do everything.
