Pretty quiet around here...has anyone been able to determine where the firmware code is on the DVD and which CPU instruction set it uses?
With that info it should be easy to disassemble the code and make small changes...such as getting rid of that blasted nag screen on the map everytime the unit is powered up. If the code uses a checksum that can be maintained on a small tweak by using a small jump instruction and putting dead opcodes in between to maintain the checksum.
Posted Apr 27, 2006 · 17:47 UTC#1
