About grounding the two wires
By G35 Mass · Mar 28, 2008in Hacks/Mods💬 3 posts👁️ 1,258 views
Posted Mar 28, 2008 · 05:31 UTC#1
I will be soldering all of my connections from my Nissan harness adapter to the harness out of the back of the Z2. Would it be OK to simply solder the two wires necessary to bypass the locks directly to the ground wire for the unit, rather then run another ground?
I don't see why not.....
Posted Mar 28, 2008 · 06:21 UTC#2
Yep
Posted Mar 30, 2008 · 13:56 UTC#3
Yep
Thank you!
