N4 bypass working but no speed, location keeps jumping
By petergunn71 · Mar 28, 2008in Hacks/Mods💬 3 posts👁️ 1,698 views
Posted Mar 28, 2008 · 05:46 UTC#1
I recently did the conversion with the wire for the N4 and now I have no speed control and the location indicator constantly needs to be modified. Anyone expericencing this?
Posted Mar 28, 2008 · 06:19 UTC#2
No. Check your antenna reception and that the VSS wire is hooked up
Posted Apr 16, 2008 · 16:14 UTC#3
yeah, agree with whtcr, sounds like vss and antenna not connected, if you ever have to modify your location more then 20 feet on the map that usually indicates your antenna is not connected. Go to menu, setting, hardware info and it should give you the readings, drive around and see what it says for ant reception and vss.
