Rear Camera not working in Split-View Mode
By osubucks · Mar 28, 2008in Problems/Troubleshooting💬 6 posts👁️ 981 views
Posted Mar 28, 2008 · 14:50 UTC#1
I am hoping this is an easy fix :?
I have a Z2 with the Pioneer ND-BC2 Rear Camera. The camera operates normally when the vehicle is put in reverse, input is displayed on the screen normally. HOWEVER, when I go into display mode and select the splt-mode (rear camera and map) I got a black screen where the camera input should be and the map displays correctly.
Any ideas?
Posted Mar 28, 2008 · 15:20 UTC#2
Sounds like your camera is being powered by your reverse lights and is therefore only on when you're in reverse. Instead, power it by constant 12v or maybe even your parking lights, if yours are always on when the car's on.
Posted Apr 05, 2008 · 00:33 UTC#3
I agree that it is currently powered by the reverse lights. I am a little green around the edges though - :oops:
I didn't install the unit originally so I am just going by instructions/illustrations. It looks like the camera comes with a power supply unit. Is this PS powered by the Z2 or by another power source (thus the reverse lights)?
Just trying to figure out which wire I need to connect to consant 12V? Is it on the Z2 or the camera? Anything/Everything is appreciated.
Posted Apr 05, 2008 · 00:58 UTC#4
The camera needs to see power all the time if you want to use it when not in reverse. Right now it is only getting power when your reverse lights come on
Posted Apr 05, 2008 · 14:31 UTC#5
Thanks but, really looking for what "wire" I need to make hot all the time and not just when the vehicle is in reverse.
Any idea what wire?
Posted Apr 05, 2008 · 18:32 UTC#6
Connect the power lead of the back up camera box (it's the one with the fuse on it) to the red wire behind the nav unit. That way it is on anytime the nav unit is on, and shuts down with the vehicle. Don't forget, you still need the purple/white wire of the nav unit connected to the reverse light so it knows to turn on the back up input automatically.
