Rear Volume Low
By HarleyManiac · Mar 28, 2008in Problems/Troubleshooting💬 4 posts👁️ 925 views
Posted Mar 28, 2008 · 18:10 UTC#1
Hello,
This is my first involvement with a forum so I will apologize in advance for any rookie mistakes I might make.
I have a D3 installed in a Dodge Ram, with Pioneer Premiere TS-D901p speakers in the front and back. XM - B/T - Ipod installed also. The sound from the front is awesome but when I fade to the rear the volume almost disappears and is quite muddy. They unhooked the infinity amp and ran new wires to the Tweeters in the dash. The front soundstage is exceptional; until you try and balance the front and rear. Any suggestions.
Thanks,
Harley
Posted Mar 28, 2008 · 23:18 UTC#2
Make sure that the rear speaker output is set to full range and not subwoofer output.
Posted May 16, 2008 · 18:53 UTC#3
I am having the same issue. I have an 05 pathfinder. Did you have to correct the issue if so how?
Posted May 16, 2008 · 19:15 UTC#4
Are you using any of the staging settings in the audio menu?
