Kenwood 7100 Help Needed
By joebanks · Mar 30, 2008in General💬 4 posts👁️ 1,494 views
Posted Mar 30, 2008 · 18:43 UTC#1
I have installed a DNX7100 in my 06 Pathfinder. Everything seemed to be working fine (IPOD, XM, Nav). Now I have installed my Kenwood BT100 (Bluetooth). Both my XM (Terk) and the BT100 plug in to the CD Changer port on back of 7100. So I plugged the BT100 into the unit and plugged the Terk XM into the back of the BT100. I guess it will run through the Bluetooth unit. The BT100 works fine. And the song/channel/XM info appears on the 7100 screen, but I get no sound.
I know this board is for AVIC's mainly, but any help would be appreciated. Thanks.
Posted Mar 31, 2008 · 01:21 UTC#2
bump
Posted May 26, 2008 · 23:34 UTC#3
I have installed a DNX7100 in my 06 Pathfinder. Everything seemed to be working fine (IPOD, XM, Nav). Now I have installed my Kenwood BT100 (Bluetooth). Both my XM (Terk) and the BT100 plug in to the CD Changer port on back of 7100. So I plugged the BT100 into the unit and plugged the Terk XM into the back of the BT100. I guess it will run through the Bluetooth unit. The BT100 works fine. And the song/channel/XM info appears on the 7100 screen, but I get no sound. ... .
Disclaimer:
1. I do not own any NAV systems...(yet)... I have not even stayed in a holiday Inn... but I have been looking and researching NAV systems to buy one.
2. This is my very first post on this subject.
Seems I saw that the XM system has to be closest to the headunit for it to work. I think it has some signals that are not passed thru the other units. (like the bluetooth unit.)
Let us know if this helps.
Posted Jun 07, 2008 · 14:34 UTC#4
try connecting the XM module to the head unit only.. see if that works.. I assume you can hear the head unit it self via speakers..
