Limit to the number of custom images?
By Paul1965 · Mar 31, 2008in Hacks/Mods💬 8 posts👁️ 2,713 views
Posted Mar 31, 2008 · 03:09 UTC#1
I would like to have 12+ custom background images in the PIM2DIN folder. Has anybody experimented to see if there is a limit to the number of images you can use on the D1?
Posted Apr 02, 2008 · 02:21 UTC#2
OK, so I loaded 20+ images into the folder and burned a new DVD. Only 18 of them show up on the D1, but now I have a new question: of the images I burned, the majority of them are extremely transparent. In fact, I can see the last viewed map image underneath the picture. If I switch to map view again, it changes to match the last map view. I've never run into this before, and most of the images I converted to PIM from JPG should have worked fine. Any thoughts?
Posted Apr 06, 2008 · 16:10 UTC#3
OK, since I seem to be the only one replying to my post, here's an update:
You can fit a total of 17 custom images on the disc. You have to delete images Aurora, Sky and Water from the PIMANIM2 folder, otherwise they get dumped into the PIM2DIN folder. Doing that leaves the default "return to original" link, but then room for 17 other images. As far as my other post about the quality, it must have been an issue on my end. After a reboot, both PIMview and PIMManager are working great at creating PIM files from JPG's.
Posted Apr 30, 2008 · 18:37 UTC#4
im pretty sure the limit is 20 images
Posted May 09, 2008 · 13:36 UTC#5
I loaded 32 images into the folder when I burned it, and only 17 (plus the "return to original" link) are available to select from. That makes 18 total.
Posted Oct 05, 2008 · 06:28 UTC#6
well i love my backgrounds
Posted Oct 05, 2008 · 12:47 UTC#7
Dude... quit bumping these old ass topics with pointless comments.
Posted Oct 05, 2008 · 15:21 UTC#8
might be an old topic but since the new dvd's are out could help people chage the new dvd's they are burning for there d1 & d2 where we always have the same gay backgrounds
